toggle menu
civicwagon.com
civicwagon.com
Sign In
Register
Sign In
Register
Sign In
Register
Home
Engine & Drivetrain
Rich car
dre1162
Wagonist
May 2011
in
Engine & Drivetrain
What are some things that may cause my rt to run rich!?
Name them all!?(:
Jaker
familEE
May 2011
Stuck injector
Busted FPR
Failing/failed O2 sensor
Plugged air filter or restriction in the air intake tube
dre1162
Wagonist
May 2011
What's FPR!?
wagodizzle
Council Member and EDM expert
May 2011
fuel pressure regulator
dre1162
Wagonist
May 2011
Would you happen to know how to test the o2 sensor!?
Jaker
familEE
May 2011
Put a new one in and see if it's better. Don't forget to reset the ECU.
dre1162
Wagonist
May 2011
How do you reset the ecu!?
Jaker
familEE
May 2011
Disconnect the battery for 10 seconds. Reconnect it.
wagodizzle
May 2011
or, just pull out the ECU fuse in the engine bax fuse box for ~10 seconds. (its easier, and you wont reset your clock and radio stations).
dre1162
Wagonist
May 2011
Thanks that sounds great!(: very helpful will update soon
fast freddy
Wagonist
June 2011
U can check it with a voltmeter.
Sign In
or
Register
to comment.
Busted FPR
