POSSIBLE short? fuse keeps blowing. inst. gauge. taillights.
i was driving home recently and my taillights , instrument gauge , licenese plate lights all went out, the most recent thing i did was change the corner lens bulbs to leds which involved splicing to a different plug, then recently i kinda fucked up my weather stripping on the roof so i think it might have leaked into my car at some point.. but i doubt it but its a possiblity. .
does any one have any expieriance with this problem at all ? im more than likely shit out of luck but its worth a try..
can replacing the fuse box be a good idea?
that could be your issue as well since adding the LEDs? its worth a shot.
i upgraded my 10 amps to 15 amps.
fuckk
Not Kidding...
I had the same situation going on and I couldn't find it... It was a suggestion from a friend who used to install radios said they did that all the time.. If you did install a radio recently... Check you radio wires.. You may have a grounding issue, from when you slid your radio back in...
I really did have that problem.. And, the radio runs on the same illumination circuit as you gauges and taillights.
Worth a shot right?
May...Be...
Really was the problem in my case, and when my friend told me to check it, I was like WTF?
