Power Seatbelt fix
I haven't seen any posts about how to fix the power seatbelts in the wagons. So I thought i'd post something up that fixed mine.
On the positive battery terminal there is this fuse box. Yes, it is for the power seatbelts. In my case the fuse box was totally corroded. So I took the 2 wire connector that plugs into this fuse box, clipped the connector off and added 2 inline fuses and put in 30amp fuses, like the factory fuse box, and hooked it up to the positive terminal.
Works wonderfully, looks pretty good too!!
when i get a pic of the inline fuses i'll post them up.
enjoy and hopefully this will help someone else out.
until a fellow wagonist showed me
possibly. it could just be one fuse that's going out or getting corroded.
When I first got my wagon the passenger belt would work randomly then it just stopped, then a few months later the driver side did the same thing. I went about a yr and a half with the beeping before I decided to take a look at it.
Any chance of a video for your Euro brothers who have never seen this before please ??
remove the lower b pillar cover (center pillar), you should see the seatbelt motor. disconect the sensor, on the motor side attach 2 wires that will run to the battery. with the wires attached to the plug, touch the ends to the pos and neg on the battery, remove the leads once the motor stops moving or if it doesnt move. if it doesnt move switch the leads to the battery. if it still doesnt work your motors are probably burned out.
i did this just to get my seatbelts back. they wont operate correctly but they will be functional and it gets rid of that annoying beep!
