Help Help Help Dpfi to Mpfi
K so i swapped in a d16a6 on my civic it formally had the d15blah blah.Anyway according to all the diagrams on this site I should have 2 open pins on 10 and 12,Well i don't i have 2 open pins on 11 and 12 so i ran the crank trigger and tdc sensor to those two.Car starts idles and everything but I have a code 4 and 20 .Crank trigger angle and power loss.Also car will not rev past 3500 RPM.What gives?Any ideas or suggestions?
check this link out, its what i used...
http://fourthgenhatch.net/mpfi.html
ive had really good luck with Ultra-8 brand distributors, which are available at napa and lordco for a little more $
http://www.hondata.com/hondata_coil_pack_retrofit.html
