What is different between Recon and Reman injectors?
I need to replace injectors for my wagon 1.6L D16A6 and found recon injectors.
Also, I found reman 93-96 prelude 2.3l (h23a1) injectors which I hope it will work in D16A6. However, I don't know what is different between them.
Actually, prelude one is cheaper than D16A6 recon one.
Thanks
Thanks
h23A1 is 375 cc high impedance
Too much fuel will cause the engine to run funny and possibly wash rings if left long enough, try some B16a injectors or d16A1 injectors from the junkyard, I think they are 240cc injectors that are obd0 compatible.
