My Stable (non-Wagons and non-Hondas)
LowFlyin'
Moderator
'91 CRX Si
Recently added (like yesterday, lol) - '02 S2000
I like Hondas...what can I say?
I've been debating an AP1 for a while now. What made you pull the trigger?
The company I work for is working with another aftermarket company that makes a supercharger kit for the S2000. So, just messing around, I went looking for a S2K on AutoTrader. Well, this one popped up 6 miles away and only has 23,000 miles on it.
So, we got the $$$ numbers to agree on both sides and I left the Miata at the dealership.
They (Miatas) are really good cars, but I don't know...guess I'm just a Honda fanboi. lol
I pulled the head off the D16A6 for the Wagon, and it looks like the block will be getting the FJ Distributors Bottom End Kit soon.
Besides, a turbo'd D16 would be more fun anyway. As long as I can keep the trans casing from breaking.
Don't let her see that! lol
I've seen 15x9s on a CRX, but it was converted to RWD, so it probably was different. I still plan on buying 15x9s and making it work somehow.
She might think you are cuter and be all for the trade. Should I PM you a pic? HAHA
Well, I can tell you a good place to start. Pick up a set of DA front spindles, they have more bow to them so you can run more wheel/tire inwards. In the back, I'm already rubbing the rear trailing arm with 225/45-15 race tires.
My set up, w/ 225/45-15, would not mount to the OE front spindles of a CRX Si, so I'm pretty sure they won't fit on a Wagon, either. A 3-5mm spacer would probably fix the inner clearance, but then you have some outer clearance issues and will have to run more camber.
The Blue Wagon was stripped and the shell was sold for $50 to bpr00civicsi.
People keep giving me cars, though.
Got a '75 Civic CVCC from a friend because he didn't have the time for it.
...and last night at our local forum's Christmas Dinner, I got a '91 Civic Si out of the Dirty Santa exchange (thanks str8shooter!).
Plans?
Nothing immediate for the CVCC, but I've always wanted a bike-powered mini-car.
The '91 Si will be getting the LeMons treatment. Anyone want to come play at Eagles Canyon May 26-27, shoot me a PM for details.
Have to stay on top of it...and I haven't over the past few months.
Spring is coming up, though.
Look at the CTR sticker a little closer, it says Tape instead of Type.
I've been reading off and on about a gut building a frontwheel drive cvcc with a motorcycle engine I think it was an R1. He has a chain drive differential hooked to the original cv shafts. I have thought about doing this before but my plan was to retain the original cars transmission. If you use a shaft drive water cooled motorcycle engine hooked to the cars 5 speed transmission depending on the motorcycle's and cars number of gears you would have like 25, 30, 20,0r 16 foward gears and 5 or 6 reverses. just use the motorcycle clutch. pick a car gear and do a slap stick style shifter for the motorcycle engine.
The FSAE team from my college days ran something similar in our car and we had good performance with it.
