My moderate Wagon build
Still really new to the forum but not to Hondas by any means. I've owned every other type of EF and finally got a Wagon to go full circle. I bought it last Monday (2.21.2011) and so far it has been doing very well. Needed a good cleaning on the inside and I've done a mild tune-up. This will be just a mild build. I was thinking of converting it to AWD but decided against it. Now I mainly want it for a good daily driver to haul the kids around in and get groceries on the weekend and what not, but it'll still have a few goodies.
I've ordered the energy suspension master kit to replace the old worn out bushings and the RTA bushings as well. Just today I changed the oil with an OEM filter, replaced the transmission fluid with Honda MTF, and replaced the spark plugs with some NGK's. Also, I replaced the stock steelies with some CRX Si alloys, tomorrow I will be getting everything needed to do a dpfi to mpfi swap and an Si cam, and yesterday I picked up a crx si rear sway bar and I purchased from Honda a new valve cover gasket set, crank seal and cam seal, and ordered from them a new timing belt and intake manifold gasket. I'll get a new water pump from them as well when I pick up the timing belt and IM gasket. Anyways, on to some pics.
Damn I need access to classified sections now!
New next to old
New brakes on!!!
I also put on the EX master cylinder but it was dark by the time I was finished so didn't get any pics.
i had ITR calipers on mine, but it was on stock knuckles not EX ones... maybe thats why
the best upgrade i ever did to my DPFI cars was drop in an Si tranny. that plus the MPFI swap really wakes her up!
