Oil in with spark plugs
so i changed my plugs today, and noticed that in all but 1 of they cylinders there was a ton of oil, i'm assuming that this is what would be causing my to burn some oil and have a little cloud of smoke when i punch it.
i know there are seals for the plugs to prevent this, but where are they located exactly? and could someone please give me a part number? there isnt really any honda dealerships out here, so i figure it'll be easier to find what i need online with one.
thanks
thanks
This is what you will see when you pull your valvecover. Arrow indicates where your gasket is bad and oil is getting into your plugs. The gaskets fit in groves on the bottom side of the valve cover.
http://www.youtube.com/watch?v=W6je9KKm ... re=related
Is the oil on the porcelain of the plug or on the electrode? If it's on the porcelain it's rare that it will seep thru and make the car burn oil it's likely the valve seals are leaking
Where is a good place to buy the O-rings under the rocker arm assembly, neither napa or oriellys had them?
