Wagon from SC
I have been working on my wagon now for over a year. Here is a few things I have done with it.
In the beginning. (small pic)
SMSP 2.5" exhaust, DC header with custom secondaries and 2.5' collector
Then I put on the GroundControl coilovers, top hats, da rear sway bar, and TR Motorsports wheels.
FastBrakes 11" front brakes.
Then I started my d16a6 build. It has a ported head with Supertech valves and springs, a cut open and ported d16y8 intake manifold, tapered y8 throttle body, Web Camshafts regrind, Arp rod bolts, z6 head gasket, 75.5mm stock pistons, block was decked for zero deck height, (should be around 10.5:1 comp.)
The intake.
Dropped in.
I also did a wiretuck and converted it to obd-1. The trans was rebuilt, new brass, bearings, seals, and a 4.70 final drive. Let me know what you think.
Nice work on the wagon I like those TR Motorsports.
