Steering Wheel with RADIO controls.
:idea: ideas & opinions needed on this topic
im swapping out the wonderful stock (Lil REDWagon) radio BAM so kindly loaned me for Wago~Palooza...
to a more up to date ebay special so i can play dvd for my daughter..
it has the wires for the radio to be controlled from the steering wheel....
I need to know which Acura or Honda wheels with controls will mount n our wagons.....
Thanx in advance
Thanx in advance
Your best bet might be through the aftermarket. I know there used to be remotes that would mount to the wheel. I'll give a search when I get to a real computer.
wiring either way would be tricky, so thats what i would do =D
cant imagine where or how to mount any buttons to it ....
unless u mean duck tape em on ....
Well, you do live in Virginia, right? lol
This is all I could find: http://www.crutchfield.com/p_130CDSR100 ... ml?tp=1068
I know there used to be one on the market that was smaller and more of a triangle shape. Not sure what compatability is with something like this. But I found it real quick just looking through Crutchfield. I'm sure there's plenty of others elsewhere. Maybe Best Buy or some other online retailer.
GL
also what deck did ya get??
sedan LX wheel ftw... same style as the 90-91 RT4WD, but with controls
junkyards have a bunch typically
This all being said, I believe EG and EFs have a different shaft, However a steering column swap may be doable (not the rack, just the column...just the metal part, so a smaller or larger toothed shaft bolted to the u-joint.)
might need to find another car to get it from...
:idea:
DOES anyone know how to verify what cars have the same steering wheel spline.. :?:
non @ the Pick-A-Part today.... :roll:
found a few wagons tho... nice parts available..
:idea: but if i find a tranny its getting pulled for a complete rebuild with an HX 5th gear and so will the rear trailing arms for the first RT rear drilled & slotted disc conversion on Scrappy....
Anyone know if any of the TL or RL or any other Acura wheels will mount n the wagons..?????
The thread is about steering wheels
wow this simple question took a few wrong turns i see.....
ok this is what i decided on getting
88-91 Prelude SI...
