I got no heat in my wagon and winter just hit. HELP!
so i noticed the heater in my 1990 civic wagon was going out. i replaced the thermostat and noticed a slight difference but its nothing compared to my gf car, or my 2000 si. anyone got any ideas. its freezing out...
when you did the thermostat did you flush out the entire coolant system..... also switching the heat from hot to cold..
heater core is probably stopped up..
:oops:
i just did my heater core. involves removing the dash, removing the hoses from under the hood, pulling out the heater unit and replace the core. You might want to check if the heater core is plugged up first. Just remove the IN/OUT hoses to the heater core and try to flush it. May also check if the value on the inlet hose is opening when you set your heat on high.
good luck. outside temp is 22 degrees over here. brrrrr!
thanks. i guess i didnt flush it enough, i kinda just drained the coolant. a friend was saying take it to a self service car wash. pop off the hose from the firewall to the head and pressure water threw it. any thought on that. it sounded good and that he did it last night. Also what hoses could he be referring to. and ya it dropped to -3 last night. FREEEZZZIIINNNGG
so im gonna wanna un plug both of them and spray into the lower. i drove it this morning and i get heat but just not as good and a true honda heater. also... lol. im having problems with my rear defrost, only the top 5 lines work, and were do i put washer fluid for the read wiper.
Its located on the firewall just to the right of the fuel filter
The heater still works i used it last night for black firday. i think i just need a coolant flush.
