Wagovan Shenanigans
Hey all, i said most of this in my "introduction" but this is my build thread so lets do a little repeating.
The car is a 1991 Civic wagovan that was given to me by a friend after he blew up the motor and sold off what he could. I got this car friday the 19th of november at about midnight. I have had MANY hondas and happen to have a ton of spare parts. So i took the wagon from shell, with no suspension but 2x4's wedged between the lca's and the strut tower to what you see below. This was all completed in 1 weekend, the 20th (sat) and the 21st (sun).
LIST OF MODS:
Skunk2 front and rear camber kit
Aftermarket lcas
Stock dc2 shocks with TIEN springs (it sits about stock ef height)
B18B1 with B16 trans (didnt have gsr)
HASPORT motor mounts
Itr header
ACT clutch
Jun Flywheel
Stock miata wheels (ugly)
Blacksworks Alum radiator
Dc2 guage cluster
LIST OF MODS:
Aftermarket lcas
Itr header
ACT clutch
Jun Flywheel
Dc2 guage cluster
i guess i know who to bother if i run into any problems :P
Want to fly out to chicago? It's 25 degrees, but I'm sure you could do just as much on my rt4wd in one weekend!? Nice work.
is the shift linkage the same deal as an ef hatch? cut it 2 3/8 inches?
i need ex/si/rt4wd front spindles and da axles?
getting my harness done by rywire so im not worried about that. already have an obd1 p72 as well.
i would just like to hear it from a wagon owner, every writeup is a hatch or whatever and as you know us wagon guys all have different quirks to deal with than they do lol.
here's what i did...
i'm not sure about the shift linkage but i have heard cut and weld works... but i got my shift linkage from hasport..
and no ur stock wagon hubs well work just take off the metal O ring in the inside of the hub..
yea rywire harness is good too but i got my from ebay sell "MONO" but i'm running obd0... good luck
do you have a dx wagovan or rt4wd? or are all the spindles the same? i am going to be obd1 cause i had the entire car to pull parts and it was a 94 gsr. if i can use my wago spindles i will be happy!
i have a DX but i'm pretty sure there all the same beside hf crx hahaha... n hmmmm i'm not sure if DC and DA axle are the same... and the only way to find out is to try... good luck...
just checked PN's and all the wagon spindles/brakes are the same. sweet news for me lol.
http://hondacrx881.tripod.com/gsrclusterswap.html
oh sorry hahaha didn't mean to butt in
