Air Pressure?
Alright, when I first got my Konigs wrapped in Kumho Supra Ectsa 712s, I put 35 PSI in them. They were riding a little rough so I let the air out to 30 PSI. Is it ok to run 30 in them? They feel a little smoother now. I just wanted to ask and make sure.
The size is 205/40/R17 btw.
there is noway around it i have 14's and i run 40 plus psi and its very nice
i had 17's on a porsche and you just gotta take one for the team if you want the looks
This set me back $180 CDN for 4 tires, installation and balancing. Also, I get free yearly rotation and unlimited flat repair.
Nothing fancy but they do the job...
I have also added the factory Civic plastic hubcaps instead of the metallic caps (as seen below on the left wagon) 'cause the plastic hubcaps hide the factory metal rims and the caps rust out...
