Wanna Clean that Engine? Use This
I use Dollar General Oven Cleaner..Cheap and works MUCH Better than any of the so called degreasers out there.
Just my .02
A Clean Engine runs cooler and smoother!
Just my .02
love this stuff!
i use "AWESOME" from the dollar and that works great...
Protect ur paint and avoid the belts..but u peeps know that already.
I will post pics soon to show the clean baby..
FYI..I still have all the factory stickers under the hood and the original owners manual..maybe I should scan it in and share with my fellow Wago's..
The UV stuff will protect your hoses...rinsing it off WELL is the key
I also do not ever follow up any of my engine cleanings with any "shiney" spray as in my opinion it looks too glossy, and dirt usually sticks worse to the shiny stuff rather than uncoated engine parts.
This pic is of a Civic that I purchased for ONE DOLLAR and the engine bay was as bad, or worse, than the dirty engine pic the OP posted:
50/50 Simple Green/water was sprayed upon cold engine. I then take a SOFT wheel brush and dunk it in car washing soapy water, scrub everything I can reach, and then hose off with a regular water hose. No pressure washer needed. I usually then crank the engine and close the hood after I wipe all reachable painted surfaces with a shammy - this sort of "steams" everything dry.
The important thing is that you do clean the engine bay.
