I just took one apart for igotcrx, the guy I sold my second wagon to & it was the switch itself. If you goto the yard you can pocket one & fix it for free
It's NOT the switch it's the resistor like "quarters" said.Pull 1 out of a junkyard wgn(or any Civic 88-91/96).If the #1 resistor is out in the 1 you pulled at the yard use the #2 resistor in the #1 spot of your broken 1.It solders in.These resistors burn out in Toyota's too. :?
The resistor is on the fan unit itself, behind the glovebox.
It's the shape of a tombstone with a 4 wire connecter plugged into it.Attached by 2 screws.Black about 35mmX65mm.#1 resistor is the weakest so burns out first.I put the #2 resistor into the #1 spot.:oops: Works fine & it'll last longer.
Yeah, i'm unsure of any part numbers but i'm pretty sure you could just pull the resistor out and take it to your local electrical hobbyist store (RadioShack over there?).
All you need to do is figure out what resistance the resistor has and go get one the same from an electronics store, mate over here did that on his EF9.
:? This part CAN NOT b gotten @ Radio Shack.
