Fan not working on #1 setting?
Kahuna
familEE
Alright, recently my AC or Heater will not work when I put it on #1. It works fine on 2-4, just not on #1. What is causing this problem?
It's the shape of a tombstone with a 4 wire connecter plugged into it.Attached by 2 screws.Black about 35mmX65mm.#1 resistor is the weakest so burns out first.I put the #2 resistor into the #1 spot.:oops: Works fine & it'll last longer.
:? This part CAN NOT b gotten @ Radio Shack.
