Clutch problem help asap
ok this car is jsut falling apart on me left and right.
I was driving and I felt the slightest click in the clutch pedal. I was in neutral, engine on and I cannot shift into gear. it was like shifting into a wall.
I turned the car off and now I cant turn it back on. I think the clutch is not disengaging.
Some people said it could be . . .
1. throwout bearing
2. release fork
3. cable
I am new to working on trannies and clutches so please help me out and explain. thanks. I need this car to drive. everything is stock.
1. throwout bearing
2. release fork
3. cable
is there any way to check that without taking out the tranny? could those symptoms be caused by anythign else?
:idea: Get yourself a Helm's Shop Manual.It'll give u the step by step procedure to fixing ur starting,seatbelt & clutch probs.
Good Luck.
where can I get a helm manual for the wagon?
http://www.hondacivicwagon.com/board/vi ... ight=helms
The 1 for a'90 or '91 will do fine for u.The best $$$ you ever spent.
:twisted: Say '"Hi" to Frodo if you bump into him.
