Dying in Idle
I have a d16a6 with eagle rods and vitara pistons. I put it in my 91 wagon an converted the wagon to multi port injection. When i start the car it starts fairly quickly and will idle around 1000-1500 rpm although it misses quite a bit. I need to check the spark plugs. After about 20 seconds of this it just dies. No sputtering or anything. I have no idea what could be causing this so any advice would be greatly appreciated. Thanks
Am I missing something? Why are you running an OBD1 ecu on an OBD0 car?
