No Brake Light's on 88 CRX
So i'm having an issue w/ the brake lights turning on. Running lights work, bulbs are not blown, and no fuses are blown. Are bad brake pedal switches a common problem of this? Or does anyone have an idea? Thanks
Put a meter on the switch and see if it's still working. Or just change it - $12 or so.
Are ALL the brake lights NOT working :?:
no the horn isnt working and the brake lights dont work. But the rear running lights do
Where are the potentially weak spots on break light wire?
