I'll look into that booster. I've been thinking of using the one from a 2wd automatic wagon, it's a good bit bigger. Seems like when I looked at the Integra one the mounting studs for the MC ears were clocked the wrong way...?
IDK if it is or not I just used the DA master also. Has a bigger res. The only thing was it crammed my engine bay a little more and was a pain to fit in there with the motor still in there!
mmm, I just bought a brand new 15/16" EX master. We did put the booster/MC combo off my red DA donor car on a friend's hatch along with the rear discs- he likes it.
Put some new NGK wires on. UGH, can I get black ones
The rear disc swap meant I had to get to the e-brake cables, which meant I had to remove the center console, which meant I had to remove the armrest, which meant removing the seats May as well vacuum it out!
Took all of my everyday junk out of the wag to load up some tires.
Big tire swap in the morning- Take the 2 off the slips, put them and 2 new ones on the meshies for the sedan, put 2 new ones on the bamwagon, take the old 2 and put them on the trailer...
I didn't realize how nice those meshies were until I started cleaning them!
Here's one from my brake-testing run yesterday. I need to adjust the rears up about an inch I think..
Today I decided to address a bunch of little things that have been bugging me. After taking my Christmas present hatch struts back and ordering replacements, I...
replaced the instrument 'hood'
replaced some cluster bulbs
bulbs in the hazard flasher button and AC switch and climate control panel
rewired the front speakers
tried another head unit-then changed it back :oops:
swapped out the trim piece around the lighter plug
changed the fan speed switch
soldered on a new plug/leads for the IAT sensor.
started work on some taillight gasket replacements
Plus did some similar stuff to the sedan. It's the little things that make your 20 year old civic a great car and not some old beater
Bam,
so you have that wild Wagon back on a leash, no more blowing apart intakes.... :shock:
I will b taking a few pix of my wagon this evening..... so I can post the start of Project "Scrappy Doo"
:idea: no more rain i hope til i get it across the field
got the 4040 PV installed
Trying on some black slips
I kinda like 'em, but just got the pair. Pretty much just traded for them 'cause the sedan needs some new rubber.
Pretty new disc brakes
and made them just like yours, basically perfect :shock:
It STOPS. Before it was just a little iffy.
Put all the interior/headliner/mirror/visors back in tonight. I hope the windshield nightmare is over :evil:
like the slips dude !
Made a few corrections and promptly went back out and smoked the clutch...in 3rd gear
pics...?
and wtf Trev haha
give me a shout sometime....
