Radiator fan wont turn off
last sunday i replaced my thermostat coz my old one is stock open (fail safe). when replaced everything back and check if everythings working, the fan wont turn off. fan will turn on as soon as the temp is warm enough to trigger the fan switch to turn on. once the fan is turned on it wouldnt turn off. i can fell the temp difference from the upper and lower radiator hoses. obd0 fan switch is located on the block on the oil filter side. i dunno if that side of the block will not cool down to let the fan switch to turn off. i was also trying to relocate the fan switch on the thermostat housing just like an obd1 set up. i got a obd1 hose barb or the other half of the thermo house from obd1 but it seems it doesnt fit right.
if you have done this or encountered this issue, please share your wisdom. thank you very much.
wagon...............................4ever......................
yeah i bleed it and everything, but its doesnt turn off once it comes on. the lower hose is so cold but the temp gauge stays at half point. maybe will bleed more on my days off.
thanks for the reply.
wagon.................................4ever..............................................................................
The bottom pipe staying cool also could mean a failing thermostat.
do anyone here have tried this conversion? if so could share some info. thanks
wagon............................4ever.................
let me know if you need a second hand or something.
thanks again.
wagon....................................4ever...........................
wagon..................................4ever.................
