They're great. There's clearance for the front discs. I'm on 13x8 vw meshies with a 1.5 lip. Though... on the free way, when I'm driving 60mph i'l be at a rough 3400 rpm!! At 70 id be at 4k+. Not good for mileage and top speeds. =(
I test fit a 13" Honda alloy on the front of my RT4WD wagon and it fit just fine.
The only thing about 13s is you probably won't get as tall a tire as stock. The stock size is 175/70/14, and the tallest commonly available 13" size I've seen is 175/70/13. According to http://www.miata.net/garage/tirecalc.html , that's 1" smaller in diameter than stock, and your car will ride half an inch lower.
Still works, though. And if I had a deal on cheap/free 13" snow tires I'd probably take it too. :twisted: As it is, I already stole my snow tires for next winter - 14s, even. I'm waiting for a rallycross in October to use up my dead snows from last winter, and then I'll get the fresh ones mounted up.
At 80mph I'm at 4100rpm in 5th with my wagon, I'm on DX Civic steels [13x5.5"] and 175/70-13s. Hopefully I'll have a decent set of 205/50-15s on Fat-5s soon enough, that'll really help top-end and mileage.
S RRY the 205's won't help your gas mileage OR topend.The extra width will cause too much drag.Your mileage will drop.Several reasons it won't help your topend:You'll hit the wgn's top speed b4 the 205's height advantage even kicks in & then that wide tire drag again :evil: ,the heavier 15's and that 6mm height increase would increase the drag under the wgn.It's only about a 1/2" difference.The only advantage you'll get is in cornering grip.That's why I like the 13's (e.g. VX or 3g HF).
