Towing Discussion
anyone know how much the rt4wd wagon can tow?
«134
    Thats a good question.
    I know they can safely hold 400KG in the boot but i'm unsure of the towing capacity.
    I called Honda Canada on that one and was told they do not have towing specs for the wagons. In fact, the rep I was speaking with said Honda discourages towing anything with a wagon. He was quite quite curt about it too and did not want to discuss the matter any further.
    I then called the local shop that, over the years, has installed all the tow bars for our family vehicles and they did not have anything standard in their inventory that can fit a Honda wagon. However, he did say I should "come on down" and he would figure something out...
  • sxy_rexisxy_rexi Band Wagon
    hehee
    well interesting that they have the granny 1st. I've heard people saying that it was for going up big hills and also for towing. weird.
    maybe once I get one I'll just have to take it to a local shop and see what they say.
    I've seen a couple CRXs with a tow hitch before. one was towing a jet ski (which was nearly the same size)
    anyway thanks for the replies.
    Well, since you have an rt4wd wagon, isn't that more for starting off slow when you're in 4WD ??
    Anyone out there with an rt4wd wagon want to comment ??
    At my local boneyard I once saw a 2WD wagon with a homemade tow bar bolted to the eyebolt that's right under the middle of the rear bumper... looked dangerous as all heck...
    The Honda rep was obviously giving me the "official line" about towing with a Honda. They don't want anyone doing it so they can't be sued if anything bad happens...
    Typical litigation-avoidance mentality... It's the same mentally that led to the installation of "automatic" seatbelts in many cars bound for the US market...
    Wow heres another one that i have to dig outta the back of my brain...
    On the old board someone went to a junk yard and grabbed the towbar setup off a civic and it bolted right up to a wagon, so i'm pretty sure it fits but whether or not it should be done is another story alltogether.
    With super low 1st i think its designed for starting off on a hill in mud/snow etc.. not really for towing, that i know of. It works bloody well though, if you nail the gas she gets sideways as all hell... :D
  • sic944tsic944t Wagonist
    well i have just finished making a hitch for my wagon a realtime i used the 2 factory tow hook things on each side as the mounting points they use 3 14 mm head bolts so 6 total i plan to tow something that weighs a little less than 1,000 pounds i have pulled a few cars behind mine in a flat tow manor and it handled it just fine
    if this is a serious interest i can document this topic
    i have had about 700 pounds of weight in and on my car before aswell on a side note
    well im definately interested in how much weight I could tow.
    the idea was being able to tow something that was 1800 lbs plus the weight of the trailer, with an 88-89 rt4wd (which another thread said weighs in at 2370-plus the driver, maybe a passenger and misc stuff so like another 300-450 lbs in the car. )
    now I know youre not supposed to tow something that weighs close to what the tow vehicle weighs.
    I don't know what the safe amount of weight difference between the two needs to be.
    and also how much the frame would be able to handle.
    and how much do trailers normally weigh? I planned to weld my own and try to make it as light as possible .. maybe get my hands on some aluminum.
    I basically want to tow my crx to the track.
    if thats not possible im still interested in some more info as even just having a trailer for hauling lighter weight stuff would be useful.
    i plan to run a d series and put a turbo or supercharger on it for some more power and torque.
    You could always just buy one of those trailers that the front wheels of the towed car sit on? A frame or something?
    You'd certainly need to upgrade the brakes if the trailer wasn't self-braking.
    I'll call Honda NZ and see if they won't weasel out of towing info.
    well there is a possibility that the crx wouldnt be registerable. so the car tires cant be on the road.
    edit: i think maybe ill just have to make it registerable and get a dolly like you (and a few other people that I have talk to today about this) suggested.
    would be a lot cheaper that way.
    still thinking about getting a small trailer for hauling other stuff though
    so any tow info is still appreciated
    :? There was a pic of a blk/blu wagon towing another red(I think) wagon @ the old site.Ask Akiraboy.Doing it with a4WD maybe another question. :? Towing a small trailer may not be a prob,but a CRX on a regular basis could eventually stress out the chassis.For what it's worth a buddy of mine had a all aluminum trailer.It was cool to see him arrive with a Datsun 240 Z on it.
    :arrow: TIP: If you do make a small aluminum trailer.Once in a while check the trailer for signs of stress cracks.
  • twalestwales Band Wagon
    I have a 1988 rt 4wd wagon and I was wondering if anyone nows if there is a trailer hitch that fits it, or if anyone has one to sell. I just need a class I hitch to pull my jon boat. Thanks
  • I believe our consensus was that Wagons need modifications to safely tow, including bigger brakes.
  • I have a trailer hitch that was made for my wagon stuck on it. The Germans wouldn't put it on the car if it was unsafe trust me. The laws here regarding putting anything on your car is ridiculous. Every time you change something to your car it is annotated in your title book. This means you:
    Got permission to install this piece
    Went and had it installed
    Then went back to make sure the inspectors say it is safe
    I will check my title book because it actually says in my title book how much I can tow safely without having additional brakes on the trailer. I believe it is something like 800kg. Most of the wagons I have looked at here have trailer hitches. I will hopefully be picking up wagon number 3 and it also has a trailer hitch.
    hahaha ragenasian you gots the bug! :D
  • Cool. We'll finally have some reasonable numbers!
  • Okay fellas I have my title book and the OFFICIAL German TUV (inspection) numbers.
    Without brakes it says NO MORE than 535 KG
    With brakes it says NO MORE than 1380 KG
    Again this is what the Germans allow on this particular car a 1992 Honda Shuttle (or wagon).
    If I was to tow anymore then what is stated brakes/no brakes then I would get a ticket and have to leave the trailer there until I brought a suitable automobile for the trailer. Again they are serious when it comes to these kinds of things.
    Also remember that here the LAW is if you have a trailer you can drive no faster than 80kmh so these numbers will also reflect that speed and nothing higher.
    Maybe this should be posted somewhere for reference I don't know.
    8) :shock: Look at the last pic:
    viewtopic.php?p=8808#8808
  • heck, I just want to install my JC Whitney hitch slider to mount my trick Yakima bike rack.
    I'm not worried about actually towing shtuff.
    altho' it would be nice.
    1380kg's comes out to just a lil over 3,000lbs hhhmmm i might have to haul my integra around with a wagon when i get one.
  • i used to have a hitch on my wagon. i've still got the hitch around somewhere, have to see if i can find it.
    it welded to the bottom of the bumper and clamped around the rear tire-down loop. it was installed by u-haul immediately after the car was delivered in early 1990, and was in constant use for several years. the second owner of the car didn't use it much, but i used it to move myself a couple times, as well as several friends. more than once we had a utility trailer loaded to the roof level of the car, with the car itself packed full.
    what would u want for the hitch reciever?
  • just a thought to consider guys..........
    regardless of how much horsepower you might have, you kind of want to be on the SAFE side with towing. A general rule to follow is to avoid anything that actually weighs the same or more than the tow vehicle even if it's on wheels. You'd think this would be obvious, but here in Wisconsin it is not all that uncommon for people to use their "full size" trucks to pull loaded trailers or boats on trailers that outweigh the truck. You can get away with it, but your load can also PUSH you anywhere it wants to at anytime if it decides to without you having too much say on the matter.
    Obviously, storage racks or bike racks are of no concern but you'd be surprised by how many junky Ford Escorts i've seen in my time towing the old fishing boat . ;)
  • Without brakes it says NO MORE than 535 KG
    This is why I posted the official Euro weights to be pulled by the wagon WITH and WITHOUT brakes.
    You can post all this info and tell them not too but they will still do it :?
    loots
    loots wrote:
    Its great hauling. Little tough up hills but not to bad.
    Another Wagon tows:
    viewtopic.php?p=11608#11608
    As a follow-up on this, I called my local transmission shop, looking to have a tranny cooler put on my '90 wagon and the owner stated that a standard transmission does not require a tranny cooler (no way to install one) and to NEVER pull a trailer in 5th gear... or that gear will burn out... which kinda supports the 80 km/h limit when towing in the above post.
  • little late.... but here's how much the official tow-capacity is in Europe: Sow I guess the same in the US?
    2wd: 1000 kg
    RT4wd: 1400 kg.
    And that's an awefull lot for officially approved numbers, I might add...!!
    Especially considering the own weight of the car: 1050kg....
  • that's pretty impressive, where did you get these numbers?
    here it's obligatory to have these numbers on your towing-hook, and also on the papers of your car. So you can show it to the police if they want to check.
    thats awesome. we can put an age-old question to rest. haha good find :D
  • Please find below some information that was provided by Ragenasian on the towing capacity of his wagon in Deutschland !!
    http://www.hondacivicwagon.com/bb/viewt ... ght=towing
