How to take off roof rack?help.
My roof rack is in bad conditions and paint is coming off. So I was trying to take it off for paint but the screws that look like hold it on dont screw out. I dont know if the guy i bought it from did some sloppy thing to it but if you guys have any info please help me.
youve got to remove the crossbars first, then you can take the screws out that hold the rails in
guess im lucky... mine came right out.
im planninig on leaving the holes there so after i paint i can put some nice looking set screws in that could be removed if i ever wanted to put a new roof rack on
Oh, and start with a narrow bit and slowly increase the diameter. The screw heads have a wide lip. I went as wide as I could and ended up boring out the hole in the rack so now I have to use spacers to keep the rack from wiggling loose.
Good luck.
