cams question
well i might com in contact with 2 heads a b20 and a b18 and im wondering if the cams for a b20 would fit/be a performance gain? reason why i ask is b20s are hard to find round here and the though of a b18 block with a b20 head is weird unless your boostin the hell out of it. input?
If you want a real performance gain, buy a set of cams meant for performance.
Check out Exospeed. They sell some decent LS cams for about $200.
http://www.exospeed.com/category.php?id=308
Uh, so?
"Regrinds" doesn't automatically mean they're bad.
either way its something like the b18b head whereas it has 1mm larger valves & its supposed to breathe better. I read this on honda-tech and on nonvtec.com.
Regrinds are not bad either...don't be discouraged by them.
Just look around
