i got a JRSC... now what lol
i have finally managed to save enough to pay off a JRSC from a fellow board member... wagowheeler. anyways, over the months i have read a few things here and there about the install, including the original JR instructions, but i was just wondering if those of you with experience have anything to contribute to the install, and use of the JRSC.
also what else i should upgrade? im getting a performance fuel pump with it already, and bigger injectors as far as i know.
how much does stuff like upgraded fuel rail, oil catch can, etc. help? im quite the Boost n00b needless to say.
anyways, any info/advice would be greatly appreciated. thanks!
Regardless, you must have this completed by March 8th. Getonitdoggoneit!
Looking forward to your install.
definitely before March 8 hahaha
pinks?
Lookin forward to seein this!
thats all
i need to reinstall AIM lol.
i will definitely hit you up man when i get it sometime this week or whenever. thanks!
as far as racing, uhhh we'll just have to wait and see! seeing as i've never driven a Blown Honda of any kind, i have no idea what to expect
Your mum dropped her panties and i fainted.
Either way, kickass and look forward to when its done!
Boosted Hondas have blown up on 5psi untuned, whilst some 15psi boosted Hondas last for years when tuned properly.
Set-up sounds cool man. Will it be the stock D15 on boost, or are you going D16A6?
i'm keeping my stock D15.
i plan on eventually doing a VTEC head conversion, or maybe just get a SOHC ZC VTEC... or non-VTEC. options are endless lol but im stick with a d-series (for now...)
...or keep it OBD0 for now and use one of the OBD0 freeware programs until you get ready for VTEC and OBD1. There really are no clear cut advantages of having OBD1 over OBD0 except for the availability of tuners and programs being more so for OBD1 than OBD0. Tune for tune you would be fine either way, but OBD1 has some different, more expansive/inclusive tuning programs such as ECTune.
As far back as I can remember, the alternator belt in the Civic has always been a ribbed belt, and yes the blower shares the same belt drive as the alternator. It's the power steering and the A/C that have evolved from V belt drive to ribbed over the years. The JRSC setups for the EF and the EK are a 3 rib drive for shock tower clearance. The EG had enough room for the 4 rib belt. Don't get hung up on trying to find a 3 rib belt though. You can take a 4 or more rib belt, and using a sharp knife, turn it into a 3 rib. It's actually pretty easy. I've done it a bunch of times without issues. Ideally you get a 6 rib belt, and make it into 2 - 3 rib belts. You will probably have to adjust the belt length (maybe even buy a shorter belt) for install on the D15 motor. The D16 has a taller block which means a longer belt than what is required for the D15.
Every 88-91 civic and every 90-93 Integra Ive bought has had a v-belt for the alt, and Ive bought way more of those cars than Id like to admit.
I was going to say maybe it was a Canada thing, but all the Si hatchs Ive bought have the sticker in the bay that says they were built in Canada.
Wouldn’t you have to ever so slightly adjust you Ignition timing because you now have boost, thus get optimal performance and economy?
That's wierd. Every Civic/CRX that I've owned since my 1st brand new Civic in 1986 (probably approaching 20) has had a ribbed alternator drive belt.
yeah its a used blower. it was $900 with some extra parts like performance fuel pump, fuel injectors... etc
i dont think they even sell them new anymore?
yeah i believe you need to retard it slightly.
Just don't go full retard!! LOL
You can get a nice RRFPR and some A/N fittings and make it all purdy for about $150. Its a great investment when you are boosted and it really makes transition/tuning smoother.
