I would get it from curt above because a lot of what you will need new from Honda isnt available anymore like the sanden compressor to start with, good luck! Go used and refill with R134a, might require a retrofit kit for the high side and low side charge ports if it hasnt been switched over to the new industry standard yet.
b.) 88-91 denotes USDM models. in other areas around the world the 4th gen wagon continued up until 96. so thats why, 88-96 but no, a unit from a '96 USDM civic wont work in the wagon.
But be ready to spend quite a bit
I had some followup questons on the above.
a) will the hardlines from any 88-91 civic work for the wagon?
b) does "88-91/96" above mean at 96 civic AC unit would also work?
Thanks
