replacement clutch
sup girls...
my TO bearing is on the fritz, so i decided i might as well replace the entire clutch if i'm going to replace the TO bearing since the tranny will be off anyway...
so my question is, whats a good replacement clutch brand? i was checking out Advance Auto and Autozone and whatever, and they have ones for $120. the brand name is Fenco.
also there is Beck Arnley and Perfection for $195... anyways, so whats a good replacement?
or should i go Performance? i want the clutch to feel OEM though. anyways.. thanks in advance
8)
8)
thanks. where can i have the flywheel surfaced? and what happens if i dont have it done
What symptoms are leading you to this conclusion? Is it possible that the behaviour you are experiencing is the input shaft bearing on it's way out?
It'll usually manifest as clutch "shudder" (judder if you're a limey), for much the same reason brake rotors will pulse, just at a higher frequency. I didn't have mine done, got lazy/in a hurry, and it SUCKS.
What I have done is picked up a core flywheel from the junkyard, had it turned, so now it's ready for next time. (That way you're not down an extra day or two trying to get it done, especially on a weekend)
yeah.. probably....maybe...not sure haha. what it is is that with my clutch disengaged and the car running in neutral you can here the tranny spinning. when i engage the clutch it stops.
thanks for knocking my head straight, Jaker.
1 CASE, CLUTCH
2 PLATE C, OIL GUIDE
3 MAGNET, TRANSMISSION
4 GEAR, DRIVE PINION
5 GEAR, FINAL DRIVEN
6 CASE, DIFFERENTIAL
7 GEAR, SPEEDOMETER DRIVE
8 ROLLER (4X28)
9 SHAFT, PINION
10 GEAR, DIFFERENTIAL PINION
11 WASHER A, DIFFERENTIAL PINION (0.7MM)
12 SHIM A (72MM) (1.0)
13 BOLT, FLANGE (10MM
14 WASHER, THRUST (34X48X1.5)
15 BEARING, BALL (26X52X15)
15 BEARING, BALL (6205UC/26) (NTN CORP.)
16 BEARING, SEALED BALL (6207) (NTN)
17 BEARING, NEEDLE (30X47X21) (NTN CORP.)
18 OIL SEAL (35X56X8) (ARAI)
19 DUST SEAL (16X21X4) (NOK)
20 OIL SEAL (14X25X15) (NOK)
21 OIL SEAL (26X42X7) (NOK)
22 PIN, DOWEL (14X20)
anyways... Haydz, im definitely getting a stock honda ISB 8)
For clutch replacement on the cheap I go to Carquest and just order what I need. They sell Exedy clutch plates for cheap, and Ive had really good luck with them in non performance (low hp) applications. They also sell the rest of the parts individually, TO, alignment tool, pilot bearing, etc...
Make sure the oil level in the transmission is at the correct height. This is the reason 99% of the time that the ISB goes out. You need 15 (the bearing) and 16 (the shaft seal). Don't change the bearing without changing the seal. If you do, you can bet that once you have it back together, and nice and quiet for a couple months, that the seal will start leaking oil all over your clutch.
thanks for the insight though Jaker.. really really appreciated!!
