VSS conversion, cable to electronic!?!?
ok so im doing the z6 head swap on my a6 block, i have the full z6 engine harness, distributor and p28 ecu. my problem is how to wire the electronic VSS from the 5G tranny and still have a functional speedo and odometer cause the wagon has a cable speedo. im only stumped on this cause in my current DD when my VSS broke it threw a CEL. do i skip the electronic VSS and stay cable or what?
any insight would be greatly appreciated. thanks
why dont you use your 4th G tranny?
if you are only doing a head swap i dont think that will be affected in any way.
PS i have full head, intake, JDM B series TB bored to 60mm
(btw, i moved this to the Electronics section)
anywho... someone else needs to answer this for you. haha... i'm out, g'night everyone.
Going to run an EG4 VTi cluster and the L3 cable box..
The City will be OBD1.
I'm still researching it but i'll let you know if i find anything.
I ran a jumped obd1, with a speedo cable, on a hydro b16 trans with no problems.
So, cable or eleectronic from OBD0 to OBD2 is all good.
Over hear we even get to nick them from Rover's in the scrap yard (Rover and Honda had a joint venture in the late 80's)
http://hondacrx881.tripod.com/gsrclusterswap.html
