Cluster lights
When I removed my cluster when i was taking my dash off, since I put it back on, they won't work.
I went through twice and made sure everything was correctly hooked up and it is. any idea? my headlights and everything else works fine. my speedometer works, just all the lights dont.
thanks in advance guys.
yeah, i did. and i already checked them all, none of them are blown.
can the little bulbs burn out?
i'm 100% positive everything is correctly connected.
i dunno. i triple checked all the connections and everything is working. i used a voltmeter and checked the wires and they're all getting power.
Is every single bulb completely out or just a few? Try pulling the easy ones out first and hold them up to the light and see if the glass has a smoked affect to it, you might have to pull a bulb that doesnt have the blue colored condom on it, pull a black base one that has clear glass and see if it looks burnt out...
