Cluster lights
When I removed my cluster when i was taking my dash off, since I put it back on, they won't work.
I went through twice and made sure everything was correctly hooked up and it is. any idea? my headlights and everything else works fine. my speedometer works, just all the lights dont.
thanks in advance guys.
    did you plug the plugs back correctly..? check fuses as well.
  • michaelhinkle1michaelhinkle1 Senior Wagonist
    yeah, i did. and i already checked them all, none of them are blown.
    can the little bulbs burn out?
    i'm 100% positive everything is correctly connected.
    Double check the wiring for your head unit. I know it sounds stupid but when people mess up the acc and remote wires this can happen.
    headunits not in there right now. and it was rewired at freemans car audio a year or so ago, they ran new wires and everything. the cluster problem just recently started. :roll:
    i dunno. i triple checked all the connections and everything is working. i used a voltmeter and checked the wires and they're all getting power.
  • Same thing happened to me when I removed my cluster and put it back it, when I was driving at night and had to turn on my headlights I noticed 3 areas of the cluster that were not lit up properly, so I took the cluster out and pulled the 3 bulbs out in the affected area, and swapped over used bulbs from a prelude cluster I had laying around, works great now...
    Is every single bulb completely out or just a few? Try pulling the easy ones out first and hold them up to the light and see if the glass has a smoked affect to it, you might have to pull a bulb that doesnt have the blue colored condom on it, pull a black base one that has clear glass and see if it looks burnt out...
