crv tranny
does anyone know if the bolt pattern for the mounts is the same as a reg hydro tranny or were i could get 5 speed b20 crv tranny
  • What hydraulic transmissions are you referring to as regular? either way, I don't know. 8) 8)
    Check out car-parts.com for transmissions (and whatever else). Good luck.
  • crv-tecwagoncrv-tecwagon New Wagonist
    a b series tranny im trying to put a 4wd tranny from a crv with a ls v-tec and put it in a 4wd civic wagon
    5 speed CR-V transmissions are almost impossible to find. i suggest calling every wrecking yard in the country!
    he tanks man i found a bunch on that sight now all i need is 700 bucks plus shiping.
    700 bucks for an efkin tranny? holy shizzz
    I think thats about the going rate for a manual B series RT4WD transmission.
    i wish i could find one at the junkyard here, $64. but thats never gonna happen *sigh* :roll:
    the price aint two bad for a rt4wd crv tranny considering iv been looking for two months and thats the firest sight with them.
  • michaelhinkle1michaelhinkle1 Senior Wagonist
    why look for shipping? buy one local, use your area code with that site, im sure somewhere within 100 miles has one?
    $700 seems more than reasonable.
    luckily for the wrecking yard, there is a niche market willing to pay it, otherwise they would sit on those tranny's forever.
    the only local ones i could find are like 1000 bucks and have more miles on them, i know there is one sitting in the back of someones shop somewhere. fuckers!
  • DD Wagonist
    I have 2. :p
    i stand corrected!
  • DD Wagonist
    quarters wrote:
    i stand corrected!
    Took me almost 2 years to find any that weren't $1000+. Patience and a bit of luck helps.
    ya want to alaberate or sell me one hu hu please, lol were did you find them and how much?
  • JakerJaker familEE
    I got mine off a guy on Craigslist. 2000 CRV tranny, pretty mint, low miles, 90 Wagovan rear diff, shifter cables/gear lever, and 2 pieces of the driveshaft (front part that attaches to the CRV transafer case and rear part that attaches to the Wagovan diff so I had both matching flanges) all for $450 shipped from Portland area to northern Washington. He had bought it all to try and duplicate the Braile Auto drift Interga, and decided to not do the project.
  • DD Wagonist
    First one i grabbed off ebay, ~ 550 shipped with the rear end. Has transfer case, but missing shifter cable bracket, and upper trans mount bracket.
    Picked up a B20 manual complete swap (again off ebay) for $435, drove to NY and picked up. Very complete swap, including axels, cable shifter, cables and transmission mount/rear T bracket.
    Also picked up a prop shaft off a salvage CRV, couple dents that won't affect my plans.
    Next on the list is to make a B series LSD fit the dual ring gears.
    I'd suggest keeping an eye on ebay, craigslist, and car-part.com, and be patient. :o
    Most everything about the crv tranny is different than the regular hydro trannies.
    The bolt pattern is different for the plate that mounts onto the tranny. The starter is in a different place. The bolt pattern for the shifter cable bracket is different, not to mention a different confiuration. The bolt pattern for the hydro to cable converter (Hasport) is different. Those sit up a little higher. Ya, you pretty much have to redo all of it.
    I bought everything for my conversion from U-fix-it Honda in Washington for 700 bucks. Tranny, transefer case, driveline, and diff. Im sure the prices have gone up, but they had the best deal at the time. That was three years ago now, damn.
  • DD Wagonist
    Speaking of opportunities.........
    http://www.hondamarketplace.com/zerothread/2326981
  • How many of you guys that have or are looking for transmissions/drivetrains are actually going to seriously try to make this work? It seems like a couple people have the stuff but haven't put time in it yet...
  • DD Wagonist
    My crv drivetrain is for my b series mini project. My wagon is getting a D16A1 + weber sidedrafts.
    Oldschool mini? My jaw just hit the floor.......... Post a project log up when you get started. Not really the response I was expecting.
  • DD Wagonist
    I already finished the front subframe YEARS ago, but a few things have put it on the back burner for quite some time (moving/house/marriage/wagovan...etc) . Just got parts for my TIG, so... maybe in the next year or so i'll have time to fab up the rear subframe and modify the front for the CRV trans.
    as it sits:
    Oh, i do have everything i need from a CRV to finish. I should tear into one of my crv trans and pull the diff soon and work on adapting a OBX LSD to the dual ring gears.
    Cleanup in Haydz' pants, i repeat, cleanup in Haydz' pants. Tracey can you get this one?
  • DD Wagonist
    and while i'm posting... i just recently finished the crank trigger setup for the wagovan... so, it might get it's motor installed sooner than later.
  • Looks real good!!! :shock: :shock: :shock: I can't say it would be my desired way to have a mini, but its still beautiful. Are you the sole pioneer in the mini+4wdcrv=supermini scene?
    EDIT: Nice work on the trigger wheel too! :P
    What is the trigger wheel for?
  • DD Wagonist
    um... i duno. I'd guess i'm the sole B series AWD mini person in the US. ringmini has a AWD D series mini (or two) in germany. and plenty of people have vauxhaul/busa/twin busa/smallblock all kinds of bizarre swaps in minis in europe.
    When I got into the B-series subframe fabrication, I wanted to keep it with factory mini suspension locations/factory length front end. I did that quite a while ago ('03) before there were kits available. Now everyone and their mother stuffs a B series in a mini... but nobody has any traction, and everyone wants more power.... :shrug: i'm going for lightness (with engine weighs in at 968lbs currently - minus glass, wiring, cooling system/etc..) , and RTawd (with a LSD up front) along with 10"x7" mags, and some meaty tires.
    maybe it'll run in 8-10 years when i get around to it. shrug....
  • Yeah, I knew they had some crazy swaps I just didn't know about the awd swaps. Props on doing the swap without lengthening; I figured you just bought and modified a kit but I'm sure if I knew what I was looking at I could've seen otherwise. :oops: :oops:
    Get it running and invite me over for a break-in session. I'll just sit in the passenger seat with a giant boner the whole time. :twisted:
