Yeah, I knew they had some crazy swaps I just didn't know about the awd swaps. Props on doing the swap without lengthening; I figured you just bought and modified a kit but I'm sure if I knew what I was looking at I could've seen otherwise. :oops: :oops:
Get it running and invite me over for a break-in session. I'll just sit in the passenger seat with a giant boner the whole time. :twisted:
lol... i'm not sure what i would have done if subframe kits were available when i started, i'm sure i've got close to 200 hours in fab/design/rework to get it how i wanted. Sure as hell would have been easier to just open my wallet.... i'll post up in a decade when it runs, feel free to swing by then.
I have a 86 wagovan, pushbutton 4x4. Built a browntop D16A1 with P29's, and i have a TWM manifold for a set of DCOM 40 weber sidedraft carbs. Crank trigger is for megajolt ignition controller (used ford EDIS components) which will give me a 10x10 ignition table, soft/hard rev limit, shift light, and a few other random things. No more distributor. (vac advance = lame, sidedrafts = )
shenrie, I'm curious about your swap ... did you use the wagon's rear diff, or the CR-V unit? If you used the CR-V's unit, what changes if any were needed for axle fitment?
Flywheel, clutch, and starter should all be B-series specific, all of which are interchangeable between B-series hydro-clutch transmissions. My Integra (when it had a B20B) had a B20 flywheel and I had no issues.
Crv diff, crv driveline modified to fit wagon. Crv inner axles, wagon outter with custom shafts. The crv rear axles are like toothpix. Im really suprised I havent broke an axle yet. Luckily when I launch, the diff is taking the majority of the punishment. Otherwise Im sure they would fail.
Sure, i moved it around in the garage so i could finish some drywall and hand some more lights.
HAHAHAH,,,i fuckin love it...why didnt you show me this piece when i was doing your hardwood floor....oh..its because you were working on my piece of shit trans
Turbo suzuki swift 4wd in a mini truck:
http://www.miniboost.no/Henrik/Div/index.html
Ringmini's RT honda d-series
http://www.ringmini.de/English_Version/ ... ld_up.html
and probably one of the originals... john coopers twin mini
http://www.mibv.com/Mini/Misc/TwiniMini/index.htm
mattyj
