White 1991 Civic Wagon
Yo! Here is a quick update. Got to work on the wagon a bit. It's pretty close to being daily worthy! Only a handful of things left.
Here is what I did last weekend:
Got some new wheels for the wagon off a friend. Super happy with them.
I really need to replace that headlight man.
I had to use acetone, heat gun, and a plastic scraper to get all the plasta-dip off these bumpers i got from a pick-n-pull. It took way longer than it should have. Curse anyone that uses plasta-dip man.
Then I used cerakote on all the black trim thing. I'm satisfied with the results so far.
Previous owner had gotten some noname exhaust and welded some piping together with his eyes closed (-_-). He ran it underneath the rear differential too. Replaced it with a magnaflow and tried to make it sit like the stock exhaust.
So close to being finished I can taste it..
  • @Exciting_Wagon64 Clean wagon you have, I’ve never used pasti dip but seeing how it works and seen videos of people taken it off seems like a process. The wheels are different seen less than a handful of people have those. How does the exhaust sound
  • edited March 2020
    Taking plasti-dip is extremely annoying. The exhaust has some really sweet notes. Not very loud which is okay because I'm trying to daily this thing.
  • This is an embed external element. It can be deleted using the delete key or the backspace key. To view the full element, press the preview button below.
    @Exciting_Wagon64 i would like to hear it if that possible do you have IG if so mine is 8.ms.9
  • Looking great! What suspension is currently on the car?
