I see a lot of post on here for the actual duck wing for the top, but Im looking for the Mid Wing that goes across the back and has the gap where the Honda emblem is, anyone know where I can find one of those???
Bumping this thread to ask if anyone has had the chance to test fit this rear visor for the CRV on the Wagon.
http://www.hondapartworld.com/cr-v-acce ... 40-S9A-100 "Aerodynamic design helps to reduce dirt and debris build-up on the rear window while enhancing the vehicle's sporty image. Black weather-resistant plastic blend is good looking and long-lasting. Rear air deflector to individualize your CR-V."
Just go measure the CR-V width.You'd probably better off getting a EF Civic SiR rear wing/spoiler & grafting it on.It'll look way better.Another one to consider is the rear wing off a WRX sedan.I did a rough measure & it should fit.
I've gone through the thread and noticed some people running EK wings I think I've asked someone on here before but don't know what thread it was but, how well do the ek wings fit and how do they line up to stock spoilers 4 10mm bolt holes?
I'm thinking about getting an adjustable ek wing if they do in fact fit well just trying to get some guidance before the buy
I'm doing the same thing to my wagon i just haven't had time to mess with it. how did you mount it to the wagons factory rear wing thing i don't know what its called
I have a red EF wing, but I don't really like the tacked on look. I think the EF wing would still need some modification to fit but I'm going to hack this one and then ideally make a mold and make an OEM looking wing.
I'm going to start messing around with mine in couple weeks to see what i can come up with i definitely want that ef wing to fit in my opinion its just the right size not to small and not to big, also i really like they have a 3rd brake light
can you get some pics?
So is he still working on it?
ebay. $160+ship, if this was 2002 these would be everywhere
I like the look of it. I bet it can fit with some modification.
Here’s a wing off a 89 civic si hatchback. I was in luck that it was stock oem Honda red ??
@little_red_swagon is that just bolted onto the black "wing" that comes on the wagon or is that piece removed?
thats what i've been seeing people do to make those ef spoilers fit they leave the factory wagon spoiler trim piece and just mark holes to fit i think
