Radiator fan problems
So I am having problems with my radiator fan turning on. I took the coolant temp sensor off and jumped it with a paper clip however that did not turn the fans on. I then tested the fan itself and it works just fine I also changed relays multiple times and that doesn't fix it I know that the car is supposed to be on the on position when jumping it but it does not start the fans. I even pulled the coolant temp sensor plug off because I was going to replace it and jumped the wired directly to each other. Still nothing. Right now I have a toggle switch wired to the relay so I can still turn the fans on/off but I would like to get it back to stock. Is there anything else I can check? I have also checked the fuses under the dash but there all good. Any help is greatly appreciated this is driving me crazy. Thanks in advance. -Jack the wagoman
