Trailing arm & LCA Problem
Hello everyone, i recently purchased an rt4wd a few months ago and love the car. Heres my problem, im installing new oem trailing arm bushings, monroe struts and new lca's. Ive installed everything except i cant get the trailing arm to reach the lca on both right side and left side to reach the lca's. It almost seems like the axles have gotten longer. Does anyone have a solution?
If this is well, yes sometimes the trailing arm, because of the suspension's geometry doesn't wanna line up with the LCA. Its relatively square when the car is sitting on its own wheels (and the strut is compressed.) It can be tricky but if you, like he said, bolt the LCA to the subframe and the shock to it, you can jack the LCA, thus compressing the spring and as it goes up, will line up better with the trailing arm.
