Pulled vents now car won't start
OK Honda gurus hopefully someone can help. I have been gutting out my 89 civic to prep for a race build and earlier after I pulled all my vents ac motor heater core etc the car stopped starting. It started fine before but now it just turns over without catching. Are there any sensors that need to be connected in order for the vehicle to run?
2. Are you getting fuel?
You could have screwed up a wire somewhere pulling stuff. But checking for spark and fuel would be a good start cause if you have both it should be starting.
http://i101.photobucket.com/albums/m69/timmahandthelordsoftheunderworld/Mobile%20Uploads/0709161906.jpg
Is the emergency flasher plugged in still? I know a lot of controls run through that. At least they do in my 90. Not sure if 89 is different.
