Looking at a wagon...
Local CL has a posting for a 1991 Civic Wagon w/auto and AC. Only has 75k miles on it. Very presentable, but it has no RH mirror and the transmission seems like it shifts hard sometimes and acceleration seems sluggish, although it just passed smog test about a month ago. Are there any inherent issues with the transmissions and can you find wagon RH mirrors anywhere?
Bill
Bill
Plus I sold my right mirror delete plate so the mirror cost me only about $20.
Good luck with your purchase.
sluggish issue could be myriad of different things, simple tune up could/may help a lot. possible issues: ignition timing could be off, catalytic converter could be clogged, etc...
sounds like the brakes need to be bled.
$4500 is outrageous for a car with the issues you mentioned, regardless of mileage. it better look brand new and be in perfect working order for that much. I wouldnt pay more than $3000 personally, especially for an automatic...
Here's current link... http://sandiego.craigslist.org/esd/cto/5007843083.html
My current ride is a 1994 Toyota Paseo, auto/AC and 43k miles on it... It will kick the Honda's butt as it stands now in overall performance. I had an 1986 wagon a year or so ago, but it was a 5 speed. Ran well after I tracked down a vacuum advancer for it.
My stock 90 2WD is S-L-O-W even with a 5 speed. It's what, 90hp on a good day? Gotta be worse with Hondamatic sucking the life out of it.
For $4500 you gotta really want it.
