driving/offroad light mounting
So hopefully this is in the right section, and hopefully I didn't miss anything in my search. I was wondering if anyone has any pictures of different ways people have mounted driving/offroad lights on the front of an rt4wd without an OEM bullbar. I would like to get some lights mounted to help with visibility during drives in the foothills and mountain roads in my area, but can't afford an OEM bullbar. I'd like to almost do a rally style mount, but don't know if it's been done before and how easy it would be. I found a mount online that is supposed to mount to the car using the license plate bolt holes, but don't see how that could support the weight of even a 3-5lb LED light bar. Any ideas, pictures, and any links I missed in my search would be appreciated. Thanks!
I've seen several people just straight mount them onto the top of the bumper. You could probably figure something out to come through the front grill off the tow hooks / bumper support and mount right in front of the bumper as well.
oh and yes its a straight bar with the spot flood combo
I just installed a set of their D2 driving beams. I will have to put up some pictures. I mounted mine to the crash bar inside the bumper and cut out the top corner of the grill on either side. Nice solid mounting and tucked under the bumper.
I should probably take the lens covers off and flip them over so the lettering is the correct way round.
These are the Rigid D2 driving pattern.
3ft - Rigid D2
3ft - 55watt HID 4300k low beam
3ft - 55watt HID 4300k low beam + Rigid D2 (this one was an F-stop of 16, very bright!)
18ft - Rigid D2
18ft - 55watt HID 4300k low beam
18ft - 55watt HID 4300k low beam + Rigid D2
18ft - 55watt HID 4300k low beam + Halogen high beam
18ft - 55watt HID 4300k low beam + Halogen high beam + Rigid D2
30ft - Rigid D2
30ft - 55watt HID 4300k low beam
30ft - 55watt HID 4300k low beam + Rigid D2
30ft - 55watt HID 4300k low beam + Halogen high beam + Rigid D2
The Rigids really looked intense when I had halogen low beams. The Rigid would totally over power out the lows, it was like the lows were not even on. But 55k HIDs putting out ~5000 lumen each makes the Rigid 3000 lumen each look weak.
Truer words my friend. Bless you! Yeah I could see 5000 lumen coming out of the HIDs overpowering most other things. But they do still help fill in more of the dark spots, which is what I'd be most concerned with myself.
On a side note, holy moly them things ain't cheap are they! Did you pay full retail on em?
