I've got a wheel predicament here....
So I have these wheels (actually for sale) that I'm contemplating running on my RT4WD. 15x7
The problem is that they're BMW 5x120 bolt pattern and a pretty high offset at 17mm. I know they make 4x100 to 5x120 adapter but the smallest I've found were 18mm thick leaving the wheels at a 0ish offset. Even with that they seem like they would poke like a mofo.. I wasn't really considering getting them filled and redrilled until I did a quick chop and actually seen what they would look like...
Fawk, now I'm looking to redrill but neither of the 5 wheel repair shops local to me won't do it. I'm not opposed to shipping these out to get done. Anybody have experience with this?
I will move this to the correct section for you
I've not looked under there extensively so I don't know what type of work that would require or if there's enough material/clearance to do so.
So if things are still making sense. Let's do it for your set up. 15x7 +17. 7x25.4=177.8 mm 177.8/2= 88.9 mm. 88.9-17=71.9mm 71.9+18 mm wheel spacer= 89.9 mm from wheel hub mating surface.
To recap for setup would be more inset,by 11.3mm, than a 15x8 with 0 offset. Which is popular and you should be able to get an idea of how your wheels will fit.
Let me know if I made any mistakes here lol
http://www.1010tires.com/Tools/Wheel-Offset-Calculator#Results
Otherwise my head hurts.
The wheels are Riken Turbos, found usually in 1 piece form and look quite different from mine:
