I am a new user and what a wealth of information this site has been. I just used these for my right rear on a 1990 rt4wd. fit kinda tight in the hub but seems like a quality part.
Brand: A-1 CARDONE
4wd or fwd: 4wd
Part #: 60-4134
Front or Rear: Rear
Left or Right: Right
Has anyone here ever checked the EMPI website. They have both axles for wagons and acura. I checked the specs on both and they are the same size. The Acura axles is little cheaper.
I can 100% back this mans statement. Literally just did this about an hour ago.
Any 90-93 B-series Integra Axles will work as a replacement for the front on a RT4wd. Went from being 80 for one axle which had to be specially ordered, to 100 for both axles which they had in stock. I will pay the extra 20 for another axle, and the convenience.
Thank you for making this thread, would have been lost without it.
Oh and I now have another question, What are the options for the Rear?
Just attempted the 90-93 integra axle on my passenger front of my '91 RT "Auto".
Did a careful visual inspection, pics too, will post later.
The integra axle is approximately 1/4 inch shorter when stood up vertically side by side and compressed. I noticed the my wagon with a centric ring seal on one end, and integra without.
Went with install anyways and terrifically everything bolted up. Bolted my wheels and did a test spend while the car was still in the air. no spend, wheels locked, assumed it was my calipers locking up to a possible faulty brake bleeding(also did brake job same time as axle). I inspected the installation today hoping it will be the calipers locking up, so I removed the complete caliper and did a test run while jacked. Sure enough, no movement. I assume the inner shaft to transmission did not have spin clearance, checked-cleared. I loosened the 32mm bolt to the axle, it freed a slight movement. Again knowing for sure the inner axle has clearance, it was now the outter axle creating a slight grind. I knew for a fact this is the issue, bearing fitment on knuckle and hub is not compatible to integra. The integra has a larger diameter.
Will post pics later..
Does anyon know if the civic auto sedan axles fit????
Hello 91rt4wd. Did you find any solutions to your rear auto axle fit? I have a 89 rt4wd and will likely need to replace all four in the near future. Thanks.
Here is some pictures of wagon axles side by side with some 1990-93 Integra axles (Integra axles have the abs rings)
the right Civic wagon Rt axle is longer than the integra one, there are some other differences too
Yes. I believe the driver's side is around 1-2" longer. I just packaged and shipped a pair out last week.
Hmm I wonder if I installed mine on the wrong sides. I have a rear leaking but I also think I overfilled! I will have to pull the axles soon and measure.
gotta get fronts now .. mine have ticked since day one and its @ the vibration stage now ..
$50 with my friend's company discount and comes with a lifetime warranty. Was $90 something without the discount though.
a picture of the RT4wd axle and the integra laying side by side .....
which is beefier ..???
how long is difference ????
will it matter with my accord spring & strut set up ..????
Brand: A-1 CARDONE
4wd or fwd: 4wd
Part #: 60-4134
Front or Rear: Rear
1990 Honda Civic Axle Assembly Driveshaft & Axle Price: $40.80 Core: $50.00 Qty: 1 Part #: 60-4134
i have one in my drivers side with the lift and havn't had any issues with it yet. only driven a few thousand on it before i pulled the motor though.
Hope this helps....
thats too bad...that'd b a cheap way to get extended axles haha
ABS rings just knock off with a hammer and with/without a drift.
I've had the privilege to work with the guys at SurTrack on my Tape-R LeMons Civic hatch and now with the wagon.
They have 100% new front axles for the 2nd Gen 4WD Wagons.
Brand: SurTrack
Part #: HO-8104
4WD or FWD: 4WD
Front or Rear: Front
Driver (L) or Pass (R): Driver (L)
Brand: SurTrack
Part #: HO-8107
4WD or FWD: 4WD
Driver (L) or Pass (R): Pass (R)
