Wagon interior questions inside
Ok I don't know if any of these questions have been answered but I could not find them. I am a noob to wagons but not to efs. My questions are can I use ef sedan door panels in my wagon? The fronts look the same but what about the rears? Also will the dash out of say a 91 sedan fit the wagon? I have brown interior in mine and it is absolutly horrid. The dash is coming apart carpet is nasty, door panels are coming apart... I have all four black door panels from a sedan and I can get a nice sedan dash so I just need to know what fits. Thanks, Ryan
    Sorry, but I don't think any of that stuff will fit. I'm not entirely sure about the dash...
  • As far as I can tell it looks like the dash and door panels will interchange. The wagon dash looks just like the 90-91 civic sedan dash but I just want to be sure before I go and spend the money and time on a dash at the local pull-apart
    I know that the doors are different: taller.
    dont waste your money if your looking for a direct fit on the dash..
    The wagon dash is longer (the portion from the top of the dash to the windshield),
    as the wagons front is much steeper... the conversion has been done
    with a crx dash though by member Aries (not very active member anymore)...
    he cut the top portion of the wagon dash off and attached it to the crx dash.
    it looked fine- but must have been a lot of work... again anything is possible
    if you got the time...
    and im sure you could still put the sedan dash in buuutttt i'd imagine there would
    be an inch gap or so from the windshied to the dash itself...
  • jdm_rolexjdm_rolex New Wagonist
    Mods- did you guys get rid of the write-up of this swap? I remember seeing it a few years back..
    It was Akiraboy that did the swap.I tested the swap @ the junkyard.The CRX dash does fit.Here's the link(next time type in "CRX dash swap":
    viewtopic.php?f=9&t=161&hilit=crx+dash+swap
    A RSX dash fits too. :twisted:
    Sdn door panels don't fit.Wgn. panels are narrower.Just go measure the outer door of a sdn in the street.
  • Low_LyfeLow_Lyfe Wagonist
    Hey bud, is there a way you could post a pic of your brown dash and seats please?
  • Low_Lyfe wrote: »
    the last post was almost 3 years old lowlyfe.....
