Reassembling the suspension components help
Hey guys so I took apart my whole front end. I am trying to put my wheels back on so I can move my car back. I am going to paint my engine bay.
The problem is I don't know which parts to connect in what order. Also I do not know if I have the lower control arms on right side/way. Here of some pictures of where I am stuck at.
Right side.
Right side.
Thanks. I now know here those that bolt goes, and sleeve. I am going to put it together today.
The bushings imo right now seem okay. I am going to look at them all though and see if any are badly worn.
Yeah. I am just using these until I order my new coil overs. I am moving the car. I am going to set up a garage tent, and paint in there. So I need to move my car to a better spot.
I'd highly recommend not replacing your struts, unless your tailgate keeps falling.
Now, I would recommend replacing the shocks and cleaning up the forks. You can get new lower control arms on RockAuto.com for around $30-60 ea.
When you buy new LCA's and Upper control arms they come with the bushings and ball joints right?
Getting ready to replace my LCA's with some from Raybestos. Should be in today.
