How to disengage four wheel drive
To tow your RT4wd wagon, or drive it in 2wd, you need to disengage the transfer gear. Having fielded this question twice in a week, I thought I'd try to explain how with pictures.
In this picture the orange lever is the one you need to move. The tube sticking up in the crook of the lever is the speedo drive. If you follow the speedo cable down to the trans. You're in the right place. With a 10 mm wrench or socket, loosen the lock bolt located in the curved slot. Then use the same tool to rotate the arm to the other end of the slot. Then retighten the lock bolt to hold the arm in place.
an automatic RT requires the same precaution, but the lock lever is accessed through the right front wheelwell. Follow the cv axle to the transmission, the lever is just below the axle hole. This picture is of the only auto RT trans I have laying around. Crusty, but you get the idea.
For daily driving, whats is the recommended option? Simply 2wd or 4wd? Any affects on fuel economy?
Gizmo posted on the Uk 4th gen forum that he did see a difference in MPG between modes.
Certainly when I push mine on the drive in 2WD or 4WD mode it's a LOT easier in 2WD mode.
Hardest thing is getting a long enough socket set in there.
Going to record my fuel usage with 2wd now and compare it with before and see if there is any difference.
He also found it understeered a lot less in 2WD mode.
I'll be experimenting here too.
Only thing is teh manual and the sticker under the bonnet says for temporary use only.
Any concerned about long term 2WD use folks?
Looking at how the mech works, it's quite similar to a gear selector synchro so should be ok, but....
Immediately I felt the car is easier to move (push) and it is faster in lower rpm's.
4WD
Distance traveled: 261.7km
Fuel used: 24.77L
Conditions: Daily driver - 50/50 town and motorway
Results:
10.56 Km/L
29.85 M/G
9.46 L/100km
2WD
Distance traveled: 401km
Fuel used: 36.18L
Results:
11.08 Km/L
31.31 M/G
9.02 L/100km
Very little difference between 2wd and 4wd.
Also tested 91 octane compared to 95 (not in this test) and didn't find any difference that was of significance.
Why not test it?
I shouldn't have said guess....It spins front wheel like mad on the snow now. Pretty certain it is but wanted to know if I was hurting anything driving it that way.
No, it won't hurt anything. It also won't hurt to disengage the rear drive if the VC is not working. Have you checked to be sure the rear drive is actually engaged?
No, but it has been working fine all along. I noticed it spun a front wheel in gravel once or twice and then when snow fell it was obvious. I guess it wouldn't hurt to see if somehow the lever moved but I'm betting it is the VC.
