Best way to help my cars cancer.
Ok I have a slight problem, my car has some pretty big rust spots on both rear fenders and the rear hatch. Don't know exactly how bad because it was night, car has no plates yet and it isn't at my house. Anyway rather than spending a lot of money taking it to a body shop, anysuggestions on fixing the rust?
then what I thought was a little rust turned into this
but I had some really good rust neutralizing paint from Eastwood.com and a welder. I welded some metal plating behind the holes on the inside of the fender well. Then I made a new lip because mine was completely eaten by rust, and spotwelded some new metal on the inner fender well.
These pictures haven't been rotated of course. I would see just how bad the rust is. If it isn't too bad I would get some really good paint to neutralize the rust. Por-15 worked pretty good for me but it doesn't like UV too much so you have to top coat it. The stuff from Eastwood is better. Cover the rust and fill and you should be good to go. Of course having the rust completely removed is the best way to go but I didnt' want to go to a body shop either. It would cost more to fix that one side than fix the whole car so we will see how long my fix lasts. So far i haven't had any rust show back up through the paint.
Good luck
The best advice is to repair it the right way and have it cut out but some of us don't have that luxury.
Good luck and hopefully it isn't too bad.
