What type of glue to glue side moldings?
Took off side moldings and pretty hard to put them back on with the clips. Been using seal all but it sucks and doesn't hold up for long. It weakens and ends up coming loose. Any reccomened glues used before? Thank you.
Without a doubt, those are going to be your best bet for a lot of reasons. I say that having been in your position, and trying tape and other adhesives in the past.
Clips simply work best.
Good luck!
bam even posted about how easy they are to pop off. Not to mention you can get them easily at the junk yard for almost nothing.
I guess if you wanna be ghetto, use some glue...
What about for the rear quarters. :P
You can get them new from Honda.
They always break.
And to be completely 100% honest, those are taped on my car LOL
Just don't rush through the process. I replaced the moulding on the driver door this weekend and took 5 minutes litereally.
Get replacement clips if you can.
Got a part number on them? Majestic shows them as discontinued.
im not trying to be ghetto! Lol
Taking them off the right way of course is always the best way, but that doesn't always happen and with parts as old as ours even taking them off the right way doesn't always result in them not breaking. Some alternatives will look ghetto, others may not.
call around junkyards to see if they got anything wagonwise
It's still ghetto.
People need to learn patience! Take their goddamn time! Bam did a write up for crying out loud. It's not hard at all. Our culture of 'now-now-now' needs to die...
And J, if you want clips, message me and I'll get you some asap!
In all honesty, I'm glad so many people are building ghetto ass cars.... makes mine look that much better lol
Charb you my good sir are Hilarious........ I found the easiest way to get the clips off while the trim is still attached, is to take a curved and straight pick set. Use the 90* pick from the top to push down on the clip lock & gently pull out the molding until the top of the clip comes out slightly. then while holding the top out use the same pick from the bottom to release the bottom locker when you release it the whole piece should pull away. do this for each clip starting from one end of the trim piece
