bogging again and with a new clicking noise
well my bogging issue came back.
i am begining to think its something to do with the ignition coil pack because some other people posting up similiar problems in the hondatech forum said it was their coil pack. if i change out the ignition coil (someone posted its also called the distributor cap) what else should i do since im there?
i also thought that the map sensor could be the trouble maker here as well but ill just do the distributor cap for now and see how it goes.
all the problems people have replaced to fix the bogging but not all of these replacements were done by one idividual but done by different people on different cars to resolve the bogging issue they had.
what they did:
checked gas tank, found rust. replaced gas tank.
replaced fuel pump.
replaced igition coil.
replaced map sensor.
found ground wire not fully ground due to rust. )cant remember where it came from /what wire the ground was from.
as for the clicking noise i have no clue to what that could be. it seems to be comming from in the engine but i have yet to go under the car.
does anyone know if all this seems correct before i go in and spend a day doing this?
what they did:
replaced fuel pump.
Of course EFs always have dizzy problems.
i have read people have dizzy problems but i have no idea what a dizzy is.
also what is a CV?
do you have pics and schematics?
i have read about the free fix.
i bought it used and have no idea if its been done yet. any way to check?
CV = axle assembly... actually, just the constant velocity joints but when they wear out, it's easier/cheaper to just replace the whole axle assembly. When they start to go, they make a clicking sound especially when turning.
Can you describe this "bogging" in more detail? Also, when was the last time the car had a good tune up?
I would start with fuel delivery and ingnition/spark strenght.
Cheers!
the bogging happends when im in low rpm.
about 1.5k rpm - 3k rpm. with slow acceleration it seems to act like there isnt enough fuel going to it or air. there is acceleration once i press harder on the gas pedal. it doesnt seem to bogg so much when i floor it. it does go when i do floor it. i just dont like to do that very much when i just drive. it doesnt stall yet but it does feel like it will eventually as the problem seems to be more frequent. i feel that what ever the part that is faulty it is beginning to get worse. another thing that happen that i notice was when i get in to turning right i would slow down and i notice the accelerator would not respond very much as i press on the gas pedal while comming out of the turn. it seems to bogg even more. it will then even out when i just wait a few seconds. the fuel tank is full of gas and i am not hitting the corner fast. just a regular driving experience. because of this issue i have not been driving very aggresively. i may even be driving like a grandma.
as something new that is happening that didnt happen before is that at idle it is idling rougher then before. the motor seems to shake much more then before. along with a clicking noise at idle. i can hear it very clearly when i am warming it up in the morning.
this whole bogging issue has only been here for about 3-4 months. so this is new. it happened when the car was completely stock. no after market parts what so ever.
not sure about the punch mark above the H. ill check that tomorrow. is that how i know they have done the ignition?
This is just my best guess from half way across the country... It could be something completely different. Sounds like you might need help from someone local...
good luck with it.
i was thinking of taking a small video clip of what is going on. for a better explaination. if its just the distributor i am good. i am more then happy to replace it. should i go with a certain brand or just oem?
When were the valves last adjusted :?: I bought a EF that ticked so loud that peeps thought I had a DIESEL.The ticking is probably NOT the Bogging prob.
Just take the Wgn to the Honda dealer & they'll tell you or for more info :
viewtopic.php?f=7&t=104&hilit=+SiWagon
:idea: If it's not been upgraded it'll save u having to open the dizzy cap.The bogging could b a bad Ignitor cutting in & out.
I've seen EF dizzies with loose parts,broken (like snapped in 2)parts & missing spark shields.
:arrow: Also check the dizzy cap gasket.When bad it lets H2o inwhich can cause no start probs.The gasket 's only a few $$.
if the dizzy is broken in half, will the car will still run?
