88 4wd into 91 2wd wagon
DDCWAGON
Banned
I have a 91 wagon 2wd AT and i was wondering if anyone could tell me what roadblocks i may run into by swaping the 4wd and MT from a wrecked 88 4wd to my 91 2wd?
the 2WD driver side is much longer then the pass. side axle...
i have no clue though if the 4WD has the same or if they are equal length half shafts... that you'de have to check out yourself
if i was you i'd just change out the entire drivertrain, basically, front hub/knuckles, rear trailing arms, axles, etc from the 4WD to the 2WD
but if thats what you are talking about then YES they are the same, heck, you can even get those on ebay or something AKA "camber kits"
If you can't do those then don't bother.
Left side is different.It's a better design.
Cutting a hole to run the shift cables.Sealing the AT hole in the tunnel.No short shifter for the 4WD.
:arrow: Just doing the AT 2 Manual is a project on it's own.
:idea: Consider swapping the clutch pedal assembly out of a Civic Sdn LX or EX.It's the same except it's set-up for cruise,then later you can add cruise or not.
here is the link
