Article: How to: Remove Fenders
After all the EF/EEs I've owned, I've never had to take off a fender. It's pretty self-explanatory, but hopefully this helps someone.
In order to remove your fender, you will have to remove the bumper to access a couple bolts. With this in mind, I documented both...
How to: Remove Front Bumper
1) Remove the three screws on each side of outside of bumper (front of fender wall)
2) Remove bumper lights by removing the phillips screws
3) Remove two screws underneath
4) Remove 4 bolts behind bumper lights (be sure to spray with PB before and use 6 sided socket if yours are rusted to crap like mine)
5) Pull one side of bumper out a bit where you removed the 3 philips screws, to get past the brace.
This should get it loose, then pull from the front and shift a little to the other side to get past the other brace.
Bumper OFF!
Bumper OFF!
1) Remove front bumper (see above)
2) Remove screw holding on corner light and pull to the front of the car (not outwards! you will break the clips). This is for a 90-91 wagon, 88-89 will have two screws on the outside.
3) Remove three bolts on top of fender in engine bay
(no duct tape was used in the making of this how-to
4) Remove fender liner if replacing, by removing the horrible plastic screws. If you're just taking it off and putting on the same one, you could probably just take out the screws attaching the liner to the frame and take it out with the fender.
5) Open the door and remove upper and lower bolts between door and fender
6) Remove mud flap by removing philips screws
7) Now you need to remove a few of the black plastic screws holding on the lower trim in order to pull back a bit to access the bolt underneath...
8 ) The fender is held on still by a bit of body sealant, so you just need to pull (up and out) with a little pressure (be sure to double check all screws/bolts in case there is a bit of resistance). Done!
did you get a chance to do this write up - cant work out how to do it on mine!
unbolt, and slide the bumper out.
Thanks
See IMG #1 by first poster.
